What are Shadowless Cards in Pokémon TCG?
Beckett news feed
admin
Site Admin
Post by admin »
The Pokémon TCG Base Set is one of the most sought after by collectors, and also the most complicated to collect. The Base Set came in four different printings, and the value of a card can vary depending on which printing run it comes from. In particular, Shadowless cards are rarer and more desirable, and we’ll explain just what this term means below. What does Shadowless mean in Pokémon TCG? If you’ve seen the highest-priced (regular run) Pokémon TCG cards, you’ll likely notice they’re all described as “shadowless.” That’s because the first two printing runs of the Base Set didn’t […]
The post What are Shadowless Cards in Pokémon TCG? appeared first on Beckett News.
Source: https://www.beckett.com/news/what-are-s ... kemon-tcg/
